How to find true TDC
Old Jul 27, 2008 | 12:12 AM
96' Formula WS6's Avatar
just wondering how to find true tdc. I need it to adjust my roller rockers. Shoebox's website tells me but I need to know how to tell if #1 is the tdc or if #6 is at tdc. I think this is the only problem with my car right now after the cam swap. That and a few vacuum lines. Thanks in advance for all your help
Old Jul 27, 2008 | 01:42 AM
ulakovic22's Avatar
Hard to tell true TDC so just get it close with the lifters on #1 on the base circle after the intake valve closes. Then do the EVOIC method, exhaust valve open, Intake closed method after you install everything.
Old Jul 27, 2008 | 07:49 AM
cnorton's Avatar
Is the intake off? If it is, you can do a quick visual check of the lifters and spot which of them is at TDC.
If #1 is at TDC you will also be able to adjust #2, 5, and 7 intakes plus #3, 4, and 8 exhausts. If any of those valves are not at zero lift, start over assuming that #6 is at TDC.
Old Jul 27, 2008 | 08:01 AM
NightTrain66's Avatar
pull #1 plug and you can place your thumb over spark plug hole as a friend rotates engine with ratchet. You will hear a "woosh" as it reached TDC. You will know this is "compression stroke" instead of "exhaust stroke".
This is close enough to adjust rockers as the lifters are definitely on base circle and not on lobes. I would not consider this EXACT TDSC for degreeing a cam but will work for the rockers.
Just rotate the engine 90* and go to #8 and so on and so on as you work through the firing order (1-8-4-3-6-5-7-2).
Good luck.
Lloyd
Old Jul 27, 2008 | 06:29 PM
FlamingChicken's Avatar
i no longer am a believer in the 1 and 6 method. when i used it on this last build i had 3 valves completely out of adjustment. one really tight and two really loose. might just be the size of cam but for me the extra 10 mins spinning the crank 90 at a time was worth getting the valves set right.
Old Jul 27, 2008 | 06:33 PM
mdacton's Avatar
thats fine on a hyd. cam...but on a solid you have to do it one valve at a time....
to do a cyl. do the intake when the ex is first openind. do the ex when the intake starts to close.
A hyd. may need to be doen that way also if it is a big cam.
Old Jul 27, 2008 | 06:41 PM
Mtxz453's Avatar
on shoebox's website it also has a chart telling you how to find TDC.. If your crank pully is keyed correctly, cylinders number 1 and 6 will be at TDC when the arrow is at twelve o clock. I just put new springs in and used this method so my valves would not fall in and it worked perfectly, valves hit the piston and do not fall in just as stated.
Old Jul 27, 2008 | 07:22 PM
Thanks for all the help, I used Lloyd's method and it worked out pretty good I just lashed them a little tighter than last time. Yea the intake was on and when I put the crank pulley on I didnt index it. Ill let yall know how everything went when I get all the little stuff done. BTW for you guys using a scorpion rocker how tight do you set the rockers when your adjusting them.
cmsmith
Apr 1, 2015 09:29 PM
Sauced
Mar 29, 2015 10:53 PM
cmsmith
Mar 14, 2015 03:48 PM
alphaauto
Jan 22, 2015 08:02 PM
