how far is windage tray from the crank?
Old Mar 27, 2006 | 09:53 PM
blackztpi's Avatar
I'm putting my motor back together and i forgot to check the height. how far from the crank do i set the windage tray?
Old Mar 27, 2006 | 10:23 PM
GetaZforgetGT's Avatar
Re: how far is windage tray from the crank?
Working on installing my tray as well.
Aftermarket tray or OEM?
To my knowledge you want it as close as possible without touching.
I know the minimum distance for the Milodon tray using there install kit is .100 inches from the crank per their directions.
I don't speak from experience so hopefully others will chime in but I didn't want to leave you swinging in the wind.
Old Apr 1, 2006 | 12:42 AM
moserman's Avatar
an aftermarket one is only gonna give u about 2 horses, if you dont have the main caps with the extended bolts to feed through the holes in the windage tray, scrap the tray all together because it will be hitting your crank. im not using one and it runs fine without it.
Old Apr 29, 2006 | 01:18 PM
Victory Racing's Avatar
The Moroso pan has a baffle in it, but not a windage tray per say. We use that here. The ARP 234-5501 has provisions for a tray, but they are too short to use the stock tray.
Jeff1904
Jun 5, 2016 05:00 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
jackpawt883
Sep 10, 2015 08:53 PM
Catmaigne
Jul 14, 2015 05:17 PM
