how the f*#@$ did this happen? my opti outlasted my engine. how much to rering/rebld?
Old Jun 25, 2003 | 03:20 PM
mineralwater's Avatar
Well, I have 95k on my stock opti..
however, my piston rings are shot, I'm getting excessive crankcase pressure, oil leaking out of random places, a spitting sound on both sides of the engine (I'm sure its not a header leak), and I'm down on power.
I need a re-ring job done on the motor.. does anyone know how much a rering job costs? A ball park figure, with stock GM ring parts.. I don't have the money to get anything fancy, as I am already waaay in debt..
Old Jun 25, 2003 | 03:35 PM
Dave C. '97 Z28's Avatar
You might be surprised, but a good set of aftermarket rings are probably cheaper than stock rings from GM.
I would say if you're having it done you're going to spend in the neighborhood of $1500 to $2000.
-Dave C. '97 Z28
PS: If the rings are worn usually the cylinder walls have to be honed so the block has to be stripped then sent to a machine shop. If the cylinders are too chewed up then you'll have to have it bored, which means new pistons.
oldschool
Feb 9, 2016 09:21 PM
rocknroler69
Apr 29, 2015 10:24 PM
grgguy
17
Feb 23, 2015 07:57 PM
Alex Barnes
Jan 24, 2015 10:21 PM
