How to drop my IAC counts
Old Jan 15, 2004 | 09:55 PM
davepl's Avatar
Well the new 396 is alive! Did some initial tuning on it today, and ran into an issue where the IAC counts were 180. I used the throttle stop screw to increase the minimum throttle opening as much as I could, but could only get the IAC counts down to about 120.
It's a 236/236 cam on 114s in a 396, and a Holley 58mm throttle body.
What do I need to do here? Drill holes in the throttle plates?
Thanks,
Dave
Old Jan 15, 2004 | 10:51 PM
kmook's Avatar
Advanced Tech Moderator
Look into modding the throttle body, do a search on BBK as those are known to cause this problem.
Here is one of many threads on this-
http://web.camaross.com/forums/showt...hreadid=149814
This should be discussed in LT1 Tech though,
Transfering.
Old Jan 15, 2004 | 10:52 PM
davepl's Avatar
Sorry, but the signal to noise ratio of LT1Tech is so bad as to be useless sometimes.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
kandied91z
Sep 30, 2015 11:43 PM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
