How do you store a camshaft
Old Feb 2, 2005 | 04:42 PM
Beyonce Knowles's Avatar
I think I heard somehwere to store it verticaly, or was it horizontally? I've got to store it for a month or 2 until I get the chance to install it. How do you do it? Thanks.
Old Feb 2, 2005 | 04:45 PM
Pasky's Avatar
Re: How do you store a camshaft
Lube it up with oil and I just keep it in a plastic bag in a box lying down.
Old Feb 2, 2005 | 04:47 PM
Like engine oil or that camshaft lube?
Old Feb 2, 2005 | 04:56 PM
Compstall's Avatar
Take your pick.
Old Feb 2, 2005 | 05:00 PM
Loadre's Avatar
Throw it in a garbage bag with a bunch of scotchbrite pads and a couple gallons of sand.
Old Feb 2, 2005 | 05:01 PM
Compstall's Avatar
don't forget the water...
BUBBA's Avatar
Vetically or Horizontally? I think you have it confused with wine.
Old Feb 2, 2005 | 05:09 PM
So I take it they're not as fragile as I thought.
Old Feb 2, 2005 | 06:11 PM
396D1SS's Avatar
Spray wd40 on it and put it in a plastic bag
Old Feb 2, 2005 | 06:40 PM
OldSStroker's Avatar
Yeah, keep the cork wet.
BK, you might consider removing the little rust spots with Scotchbrite wet with some mineral spirits. Then wash the whole thing in mineral spirits, not gasoline! Slobber it up good with motor oil. You could wrap it in plastic to keep the dirt off, but moisture resistant brown paper would be better. If you trap moisture inside a sealed plastic bag, there's a better chance of rusting.
If you are really ****, find a little desicant bag which absorbes moisture and toss that inside the wrap. Store it somewhere it's heated, again if you are ****. Under your bed is nice.
Cams and cranks don't bend under their own weight when stored horizontally.
Old Feb 2, 2005 | 08:38 PM
indieaz's Avatar
Oil it and wrap it in a bunch of cling wrap (the kind of stufff you wrap food in). Seems to work real well.
Old Feb 2, 2005 | 08:44 PM
Silvershark's Avatar
A Crankshaft you want to normally store upright so you dont warp the crank, the camshaft is more forgiving. However, if you can I would stand it upright as well. Just dont want it to knock over and fall on the floor and break. I have mine stored in a box sitting upright.
Old Feb 2, 2005 | 08:58 PM
romoranger's Avatar
i have mine just sitting on my shelf awaiting install, but maybe i should do what everyone else is doing..........
Old Feb 3, 2005 | 03:14 AM
1racerdude's Avatar
If it's one that makes real good HP--- Ya wrap it up in towels and store VERY carefully under the PJ's in your drawer so as not to get a scratch on it.
Just in case ya wanted to make HP in the future.
Old Feb 3, 2005 | 03:22 AM
atljar's Avatar
Under your pillow for the cam fairy!
