How do you route the #7 wire?
Old Jun 14, 2004 | 03:11 PM
Blue89Bird's Avatar
I've burned through 2 of them in the last month and this is really getting old.
Anyone have any pictures, diagrams or advice or anything, I'm really getting sick of this.
I have stock dual cat manifolds and the car is a 96 BTW
Old Jun 14, 2004 | 03:18 PM
ChickenScreamer94's Avatar
It should go with the other wires in a big loomed tube at about the #1 plug, then connect to number 3 or 5 with some other kind of bracket (or use your own) and then go into a holder that is tucked under the manifold and goes all the way out to the number seven plug. It loops around like a J that is rotated a quarter turn counter-clockwise, then goes on the plug.
If you want get a really long wire and route it throught the motor mount or something.
Old Jun 14, 2004 | 05:20 PM
Looks like this.
Old Jun 14, 2004 | 06:46 PM
JDBlaze85's Avatar
1 word
Cable ties!!!!!!!!!!!!!!
Old Jun 14, 2004 | 10:09 PM
Blue89Bird's Avatar
Originally posted by shoebox
Looks like this.
Just wanted to say I love you.
Question though:
http://tiger.towson.edu/~jklein3/ima...plug_wires.jpg
That lip that the wire runs underneath, does removing the bolt i highlighted remove that piece? Is it just open underneath of that to fit the wire through?
Do you think if I wrapped the wire in heat resistant tape it would fit underneath of that still?
Old Jun 17, 2004 | 09:13 PM
Blue89Bird's Avatar
TTT
Shoebox?
Old Jun 17, 2004 | 10:19 PM
Question though:
You only have to loosen that rear bolt as the channel is slotted. There is another bolt (visible here ) in the front that has to come completely off. It is just a U-channel that the wire sits in. Big enough for the wire and the stock convoluted tubing.
Nov 18, 2023 07:21 PM
thenewkid
Apr 12, 2015 07:42 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
