How do you determine your gear ratios?
Old Dec 19, 2003 | 01:17 PM
eaalto's Avatar
As far as I know, my car is stock. All I've done so far is cai and i was wondering if there was any way I could figure out what my gear ratios are. I had the car up on a lift yesterday and I was looking at the rear differential but I had no idea what I was really looking for so it was a lost cause
But yeah I guess I just want to know the simplest way to figure out what gears my 93 z28 a4 came with stock.
Old Dec 19, 2003 | 01:26 PM
DrewHMS97SS's Avatar
jack the back. mark a hash on the tire and drive shaft. spin the tire 1 full rotation while counting the rotations of the drive shaft. 3 ~12 rotations should be 3.42
Old Dec 19, 2003 | 01:34 PM
ibanez6rg's Avatar
If your shifter goes to 1st you have 3.23s... If it only goes to 2nd you have 2.73s.
Old Dec 19, 2003 | 02:00 PM
GreenDemon's Avatar
Just cruise on the highway and see what rpms you have.
I've got 3.23s.
4th gear at 60mph=1900 rpm
My V6 Camaro came with 3.42s.
4th gear at 60mph=2000 rpm
So I'd say if you've got 2.73s you'll be looking at 16-1700 rpm.
- and you can't shift a 2.73 car into first with the shifter, unless the little thing that stops it has been cut off.
Also, I believe GU5 is the code for 3.23s.
Old Dec 19, 2003 | 02:01 PM
eaalto's Avatar
shifter goes to first...so based off that i can assume I have 3.23s?
Old Dec 19, 2003 | 02:10 PM
96ZRDR's Avatar
Look in your glove box, and look for GU5 = 3.23 gears, if anything you can also check your shifter plate, it should have P N R D 3 2 1, is you have these you have a 3.23 rear end.
Old Dec 19, 2003 | 02:26 PM
gamecockfan04's Avatar
In your glove box you should have a code list that tells you all the options on your car originally.
If you have one of these codes thats the gear you have.
GU2/2.73
GU4/3.08
GU5/3.23
GU6/3.42
Here's a complete listing of codes: http://www.fbodymotorsports.com/9302rpocodes
Old Dec 19, 2003 | 02:34 PM
ibanez6rg's Avatar
Yes.
anmar A
May 2, 2015 06:59 PM
thenewkid
Apr 12, 2015 07:42 PM
mattstrike
Mar 10, 2015 04:46 PM
Jul 4, 2005 05:00 PM
