How do you check for a spun bearing?
Old Feb 23, 2004 | 08:17 PM
LT1Noob's Avatar
Other than cutting open the oil filter....can you take the oil pan off and be able to tell? Or would a mechnic have to pull the entire engine to check?
Old Feb 23, 2004 | 08:21 PM
FastZinTennessee's Avatar
Knocking sound, fluttering oil pressure, metal in oil, locked up motor All symptoms, maybe others can chime in with more.
Old Feb 23, 2004 | 08:29 PM
LT1Noob's Avatar
I don't have knock, idle is fine, oil pressure stays around 15-17.5 at idle, depending on temp, 45 psi at WOT, and doesn't overheat.
Last two oil changes, I found some 'glitter' in my oil. There were about 30 pieces, none big enough to feel between your fingers. The car has what appears to be a minor case of lifter tick/or exhaust leak, but I dunno. I'm taking it to the mechanic this week, and wanted to know what he will do to check.
Some backround info: I got the car a little over a year ago, with 32k miles on it. Carfax showed that it was a 'clean' car, and the last emmissions test it had was back in 98, with 30k mles on it. Basically, the owner put 2k miles on it in the four years before I bought it
I'm wondering if the bearings went bad because it sat for so long. Other than the minor lifter tick, the motor runs strong...no surging, stumble, hesitation, ect. Temps are normal, and there are no symptoms of a spun bearing...just the metal flakes.
I was planning on going forged/383/396 sometime soon...but just not right NOW. How much can I expect it to cost to be rebuilt to stock specs?
Old Feb 23, 2004 | 10:37 PM
LT1Noob's Avatar
ttt
Old Feb 23, 2004 | 10:45 PM
ibanez6rg's Avatar
I think some glitter is normal...
Old Feb 23, 2004 | 11:11 PM
will62085's Avatar
im not trying to scare you, but mine did that for about a week...then lost power and all the lifters started knocking...after it just would barely move anymore i tore it down to find a cam bearing that was spun about 170* ... but now i have a forged 355 on the way
Old Feb 23, 2004 | 11:27 PM
You look until you see this, then you stop looking.
A spun rod or main bearing will normally give a knock, sometimes maybe just on startup and then more constant after the engine is warmed up. It would depend on the severity.
Old Feb 23, 2004 | 11:30 PM
will62085's Avatar
WOW...how long did it run with the spun bearing??...my cam doesnt look like it has any extra wear on it, the bearing does...but the motor barely ran when i pulled it
Old Feb 23, 2004 | 11:34 PM
Ummm... probably about 50 miles of "machining while you drive". Unfortunately, there was a little too much taken off.
Old Feb 23, 2004 | 11:35 PM
Dave88LX's Avatar
http://paradox.shacknet.nu/dave88lx/formula/clack1.mpg
http://paradox.shacknet.nu/dave88lx/formula/clack2.mpg
http://paradox.shacknet.nu/dave88lx/...a/knock/17.jpg
http://paradox.shacknet.nu/dave88lx/...nkjournal2.jpg
http://paradox.shacknet.nu/dave88lx/...k/bearing3.jpg
http://paradox.shacknet.nu/dave88lx/.../camshaft4.jpg
http://paradox.shacknet.nu/dave88lx/...ck/lifter2.jpg
http://paradox.shacknet.nu/dave88lx/...unbearing5.jpg
Old Feb 23, 2004 | 11:45 PM
Dave, I think mine had a cleaner wear pattern.
Interesting that you pulled your engine before I did and I am back driving mine again...and you're...well...still looking for an oil pump.
Just funnin'. I just put mine back together with stock stuff. Yours should be a bad machine when you get done.
Old Feb 23, 2004 | 11:56 PM
will62085's Avatar
is all that damage on the same motor?...thats about what mine sounded like btw, lol
Old Feb 24, 2004 | 02:17 AM
Smokin95Z's Avatar
Don't know about it firsthand, but I've heard that if a bearing spins, it'll sound like a squealing belt kind of... Just a constant high pitched squeal or whine. Like I said, I don't know firsthand, this is just what I've heard.
Old Feb 24, 2004 | 03:18 AM
97 RedSS's Avatar
Mine didnt make any noises..It just wouldnt hold an idle very good and also the oil pressure was going up/down and it was running 25 degrees hotter than normal..I spun about 3 mains and 5 rods
Cody
Old Feb 24, 2004 | 08:17 AM
Mine did let out a couple short squeals at idle, nothing constant. In pain, I guess. Oil pressure and temp were perfectly normal.
