How do you check PTV clearance???
Old Feb 23, 2005 | 05:07 PM
trans9_5am's Avatar
How do you check piston to valve clearance on a given setup? I want to try and run a thinner head gasket (impala .029" compressed or Mr Gasket #5716 .026" compressed) but want to check clearance before hand. Also, is there any feedback on running the Mr. Gasket compared to the Impala one?
Brandon
Old Feb 23, 2005 | 05:23 PM
Re: How do you check PTV clearance???
I suppose you could always use a dial indicator to check it.
Old Feb 23, 2005 | 05:34 PM
trans9_5am's Avatar
Well im no mechanic so would you mind giving some more details about how to go about doing this? Im sure i can get ahold of a dial indicator though.
Brandon
Old Feb 23, 2005 | 05:48 PM
RE AND CHERYL's Avatar
What cam are you using? In stock form the LT1 is a non-interference motor. This means the valve can be at full lift and the piston at TDC and still not hit. If you are using a mild cam such as the Hot Cam or 305, you will never have problems using the thinner gaskets.
Old Feb 23, 2005 | 05:56 PM
Robs97Z28's Avatar
The easiest way is to use modeling clay. I know it isn't the most accurate method, but it will get the job done.
Old Feb 23, 2005 | 06:19 PM
With all the posts I have seen of valvetrain damage after a timing chain break, I am not so sure the LT1 is a non-interference engine (I don't know if they were all stock cammed).
A quick trip to Google gave this method that does not need the head removed and only uses a feeler gauge.
You can always Google for more.
Old Feb 23, 2005 | 06:43 PM
trans9_5am's Avatar
Thanks guys, ill check it out and see what i come up with.
Brandon
Old Feb 23, 2005 | 07:59 PM
Bud M's Avatar
That's how I've done it
Old Feb 23, 2005 | 09:09 PM
It's a little hard to use the clay method on an engine that is assembled (and not wanting to disassemble).
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
