how do you check for a leaky injector?
Old Sep 15, 2003 | 11:57 PM
anasazi's Avatar
how do you diagnose a leaky injector? i have a hard start condition that seems to be time related and a misfire.
Old Sep 16, 2003 | 12:06 AM
Take the rail bolts loose and leave all the injectors connected to the rail. Pull them up and out of the intake so you can see the bottom of them. Let them dangle over the holes in the intake. Pressurize the fuel rail with the key or the prime connector. Observe the bottom of the injectors to see if any of them are dripping.
Old Sep 16, 2003 | 12:52 AM
faded93bird's Avatar
uhh what would happen uhhh if you tried to crank the motor when the injectors were out
Old Sep 16, 2003 | 07:56 AM
It might start for a second, but would die because of the huge vacuum leak.
Old Sep 16, 2003 | 08:01 AM
93transam1234's Avatar
ok
so would you do the same but take off the coil wire and try to start the car to check for clogged injectors?
Old Sep 16, 2003 | 08:05 AM
Re: ok
The best thing to do is to jumper 12v to the fuel pump prime connector. That will run the pump continuously while it is jumpered. The key does not have to be ON. Your fuel rail will be fully pressurized and you can look for leaking.
Old Sep 16, 2003 | 08:39 AM
What about looking for clogged injectors? do cloged injectors leak?
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
