How do you bleed the breaks on a 96 f-body car, please hurry
specifically a 96 camaro ss, if it makes any difference(You never know if it does).
How do you bleed the breaks??? I just installed a line lock and now need to blead the brakes....respond ASAP please!!!
gotta start out with the bleed screws on the abs unit first, bleed te rear one first and then bleed the front one.. then move on to the right rear wheel, bleed that a couple of times, then move on to the drivers side rear, then the passenger front, then the driver front, then bleed the abs unit again just as above...
then do it all over again
then you should be good to go
then you should be good to go Last edited by InjectedSS; Sep 24, 2003 at 04:31 PM.
Jul 4, 2005 05:00 PM
