How do RPM's heads compare to say an LE2 job?
Old Sep 19, 2005 | 03:25 PM
flatlander757's Avatar
http://www.revolutionaryperformance.com/products.htm
Under "Domestic Heads:"
SBC LT1 heads, matched set, 3 angle valve job, surfaced, new 2.0/1.56 stainless custom valves, HD springs, retainers, locks and positive seals
$850.
How do those compare to Lloyd's LE2 port job?
And just wondering... The 195cc AFR heads listed right under the LT1 heads are for just standard SBC right? Not the LT1?
Old Sep 19, 2005 | 04:04 PM
blahster's Avatar
Re: How do RPM's heads compare to say an LE2 job?
I would say that they might be comparable. but rmp doesn't list everything about the heads that you should know before you buy...i.e. flow numbers, CC size. etc.
you might want to find that out before you buy...
Old Sep 19, 2005 | 04:19 PM
Z95m6's Avatar
It doesn't even list porting. Basically everything it lists is to rebuild the heads unless i missed something. If you want a good set of heads go with Ai. Now that they have some new prices on stuff, i think their product and service would be almost impossible to pass up.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
Roadie
Feb 16, 2015 10:34 AM
