how do i Winterize???
Old Sep 13, 2003 | 06:12 PM
SSnakeEater's Avatar
Winter is just about here. It is supposed to snow tomarrow here in CO!!!
i dont want to drive my car in the winter and snow and cold and everything. Is there anything specific i need to do maintnence-wise to prepare for my car to just sit for 4 or 5 months?
my garage is full of crap so ill probly just end up storing it out on the driveway.
any tips?!?! thanks
Old Sep 13, 2003 | 06:26 PM
Z28max's Avatar
Re: how do i Winterize???
Move to So-Cal for the winter.
Old Sep 13, 2003 | 06:28 PM
Black_Z28's Avatar
Well, start off by filling your tank up. And throw some sort of fuel stabilizer in the tank. Some people say to change your oil, but that's a waste. Just change it right after storage. Also, get a nice car cover since it will be outside. Remove your battery. And that should be about it.
Old Sep 13, 2003 | 06:32 PM
will my tires develop flat spots? do i need to over de/inflate them or something?
and why should i remove the battery?
thanks 4 ur help
Old Sep 13, 2003 | 06:44 PM
Z28max's Avatar
thanks 4 ur help
If the car is going to sit in one spot you should put the car on jack stand and remove the wheels and tires. Stack the wheels on their sides off the floor inside. You can hurt the sidewalls if you leave it sitting on deflated tires and the rubber can start to rot if just left sitting for a long period of time outside.
Old Sep 13, 2003 | 08:15 PM
97LT1F-Body's Avatar
I would park it somewheres in doors for the winter, but if you absolutely have to, first thing is: remove the battery, put on a car cover, put car on jackstands (I leave the wheels and tires on, their off the ground at least). And have fuel tank at 3/4 or full (keeps down on the condensation in the tank). This is what I do every year in Michigan. My car is in storage right now, since OCT '02. Also, make sure your radiator has the right mixture of antifreeze to water. If your winters are cold like they are here in MI. Trust me, it will freeze.
Mike
P.S. make sure all fluids are full. And check the car every once in awhile during the winter months making sure no little critter has made a home in your car.
Old Sep 13, 2003 | 10:53 PM
john96ws6's Avatar
Oh dear god, please no, the last thing I want to read is a winter post!!!! Its still summer dammit!
Old Sep 13, 2003 | 11:35 PM
BadAssed93Z's Avatar
your getting your car ready for the winter?
i wont even take mine to the track for another couple of months.
it was a nice cool breezy 80-85 degrees here and the the coldest its been all week.
Old Sep 13, 2003 | 11:46 PM
JoeliusZ28's Avatar
I live in Michigan too, but I think that this time of year is the best to drive it Its dry and an average 75 dg outside. What better could you ask for?
Old Sep 14, 2003 | 01:51 AM
My Z is in storage only because Im overseas right now.
Old Sep 14, 2003 | 10:23 AM
Black_Z28's Avatar
I wouldn't put my car on Jack Stands. This can affect your suspension components. The suspension of the car is meant to have pressure on it at all times, and if you remove that pressure for a long period of time it could mess it up. If you're worried about flat spots on your tires, get some el cheapo rims and tires. You could even get them from a junk yard if you want. Just get them in the correct size bolt pattern.
Old Sep 14, 2003 | 11:12 AM
gb95zconv's Avatar
I would just run take for a quick spin a couple of times a month on nicer days and keep the tank full.....it needs to be driven if possible.
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
maverickmk
Sep 1, 2015 09:17 PM
97SSdude
Aug 21, 2015 09:36 AM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
Cam's maro
Aug 11, 2015 07:45 AM
