How do I test the opti feed signal to the pcm .
Old Aug 26, 2007 | 02:55 PM
90 Z28SS's Avatar
What value is sent to the pcm from the opti on the feed wire ? I tried using a test light to see if the opti was sending a signal to the pcm and my test light wont light . Not sure if its a pulsed signal or not . do I have to use a volt meter possibly to test this wire ???
Problem in short , is the rpm signal to the pcm is intermittently lost ...result , when the car is sitting there idling or driving or down the road , the car just shuts off like u turned the key off . Its just instantly dead. Theres no specific time , temp , rpm ect ect this happens , it is completely random . The car has a big stuff 3 pcm and an adapter plug and play harness to adapt the pcm without splicing . Im trying to isolate were the rpm signal is being lost to determaine if its actually the pcm or jumper harness . Coil , ICM , Opti( 2 different ones ) , Opti harness is all brand new stuff and all tested good .
At this point Im at a good spot to isolate this , as the car has went from randomly shutting off , to now ....it will not fire at all , it will just crank .
Thanks for any help
Old Aug 26, 2007 | 06:39 PM
90 Z28SS's Avatar
Ok , I have more info .
I replaced the ignition switch on the column because I had a spare . No change .
Tested the circuit with a dmm , these were the results .
Coil module :
I had my meter set at 750 dc , I forget how to read it . I assume 24 is not 24 volts ?
....with ignition on
A terminal: 24 dc
D terminal : 24 dc
....while cranking , for ac I had the dmm set to 20
b terminal .10-.16 ac volts
Opti feed wire , reading taken at the pcm connector B3
10.3-10.6 volts
....aslo the injectors are pulsing while the engine is cranking .
Im totally stumped as to why this thing wont fire and randomly shut off prior . Im totally out of ides here ....grrrrrrrrrrrrrrr
Old Aug 26, 2007 | 08:30 PM
Dave89IROC's Avatar
thank shoebox
http://shbox.com/1/4th_gen_tech2.html#opti_test
Old Aug 26, 2007 | 09:09 PM
90 Z28SS's Avatar
Originally Posted by Dave89IROC
That is the link I used to orginally to test all the voltages , and yes a BIG thanks to Shoebox ....it helped tremdously today . Everything in this car checks out seemingly fine , and it still wont start . Ive got a brand new GM opti on the car right now , so I took my spare Billet opti that I originally wrongly assumed was bad ....unplugged the opti harness , set the spare opti on the the intake and plugged it in with the key in the run position . spun it by hand and heard the injectors pulsing and the ignition making noise . So that imo , is at least telling me the big stuff pcm is good , the jumper harness is good and everything else Ive checked comes up as good . Took off the accel 300 box and borrowed a friends coil to try , the module is new . With everything else Ive done , I just dont know where to possibly go next .
Old Aug 26, 2007 | 10:23 PM
sam pace's Avatar
Sounds familiar let me know your results please.
Injuneer
Dec 15, 2014 09:36 AM
naaz90
Jul 27, 2002 08:22 AM
