How do I set the correct gap on a modern spark plug?
Old Jul 2, 2008 | 10:01 PM
Loading's Avatar
I'm changing the plugs on my 94 trans am. The correct gap should be .050 the spark plugs the guy at napa sold me are NGK Iridium IX and they are right about .040
I tried using an old spark plug gap setter (round guy with varius 'sizes' that you just press through) and the damn thing broke the electrode.
Should I worry about setting the gap? If so, how do I set it without breaking more 10$ spark plugs?
Are these spark plugs any good? (TR5IX 7397)
Thanks!
Old Jul 2, 2008 | 11:04 PM
jclark311's Avatar
I just did mine with a feeler gage, didnt have a problem, gently worked it under the electrode to set gap, if the gap was to big, i tapped the electrode down lightly with the rubber hande of a screwdiver.
Old Jul 2, 2008 | 11:08 PM
kylersaulsbury's Avatar
you shouldn't gap iridium or platinum plugs. they are pre-gapped. and as you found out it will break the electrode.
only re-gap copper plugs.
that is what i have always been told and never had a problem.
Old Jul 3, 2008 | 07:35 AM
95Blackhawk's Avatar
The 0.050 gap is for emissions. Gap to plug manufacturer's spec's.
Don 97 SS's Avatar
Yes, they seem to last forever. I hate changing plugs in LT1 F-bodies.
Old Jul 3, 2008 | 09:16 AM
BUBBA's Avatar
Just be careful when gapping them. Use a plug gapping tool---a few cents or free from Auto Zone. Dont use blades that are used to gap points and rockers. Just as you don't use a torque wrench when installing plugs, you don't use a crow bar when setting the gaps.
Old Jul 3, 2008 | 01:50 PM
CGrant's Avatar
ngk tr-55's, problem solved!
tr-6 if your juic'n
mritter1965
Feb 9, 2015 07:01 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
