How do I monitor knock?
I was just reading that many of you guys have like 8 degrees of knock and when you installed the LT4 KM, the knock went down to 2 degrees (this is just an example). How do you monitor how much knock retard you have? Do you need a special tool or something? Thanks...
Yeah, you can read knock retard with something like a Scanmaster, Autotap, or OBDII software from http://www.obd-2.com
For the last two you'll need a laptop.
