HOW do I MAKE THIS CAM work. MOTOR GUYS GET IN HERE!!!!
OK LT1' builder I need help
First of all. Imstuck with this cam. I belive that this cam is TOO big. BUT OH WELL. I have no cash right now. So heres my Question
HOW DO I make this CAM work EFFECTIVLY
Cam specs:
224/236 .501/ .510 lift 112LSa the cam is custon from Combination Motorsports.
I need IMPUT Fast.
HOW hard isit to do a CAM swap? Om considering the LT4 Hot cam and Rockers from Thunderracing for 2bills. I need help
I would really like to get my current CAM to work.
Chris
Cam specs:
I need IMPUT Fast.
Chris
What exactly do you need help on? Installing that cam is going to be no different than installing any other cam. Also there are many people running larger cams than that, so I dont see it being to big. Throw it in, get your computer re programmed and enjoy!
Aaron
Aaron
NO i dont have Springs YEt. I was gonna see if i can get away with the stock springs for now until I get more cash. BUt if I have to swap the Springs then i will. At first my motor was not getting any oil to the TOP END. acutlly very LITTLE oil was pumping. We took off my intake. the oil pump was fine. BUt we looked at my lifters and they were softer than ****. SO Im gonna replace though as well. IM about this close in putting in the LT4 cam and say the hell with it.
ttt
ttt
Just so you know the lt4 cam is different than the lt4 HOT cam. Also, I really like my hotcam but I think you would be happier with the custom xe grind. Either way you are going to have to replace the springs. The stock springs are hardly good enough for the stock cam. The LT4 springs are rated up to .525 of lift, which is exactly what the hotcam has with 1.6RR. So at the very least with the hotcam you would need the lt4 springs. If I were you I would go ahead and install the 224/236 cam and then look into the springs that Combination offers that are good to .600 lift. They are suppose to be reasonable in price, rated to a high lift, and Im pretty sure they are still a single spring design which will make the install a bit easier for you.
Aaron
Aaron
So a GOOD Programming of the computer. New Rockers lifters springs. and A Torque Converter. That should be good?
I mean i dont wanna get to deeper than the intake manfold. So i really would like to make the cam that i have work good. Thass Y i needed to know what is needed. I got the cam from a shop in Vegas. And i know it should run real good with NItrous. SO will see
ttt
ttt
I asked a performance shop today if they had springs that supported my cam they said they did. THe onl thing he siad was. That I would have to CUT the HEads to make these springs fit. (what the hell was he talking about and how much more work is that) CHris
Rockers you dont have to have, but its recommended to get 1.6RR. They will help add a bit of hp. If money is really tight though the stock rockers could be used but probably shouldn't. Springs and all the new stuff to go with them should be ordered for sure, DO NOT reuse your stock springs..You said the lifters are junk so get new lifters. And a program of the computer again is something that doesn't HAVE to be done but it really should. Without it your car is going to run but its going to run like crap, bad gas mileage, and I wouldn't be surprised if the car wasn't any faster untill you get a programming done. You may want to check out www.pcmforless.com . Bryan does great work for the price and is a good person to work with. You can probably get away with your stock converter for now but a new one with a higher stall would help a bit too.
Aaron
Aaron
Aaron
Well hey thanks for the help. IM gonna get those things. ILL give COMBO a CALL tommorrow. I will need to replace the rockers cuase the stock rockers were hitting the stud on the way down. SO heres my next question. DO i get FUll ROLLER ROCKERS or just Roller TIPS?
CHris
ttt
CHris
ttt
Lt1son
Dec 31, 2014 01:35 PM
