How do I keep the crank pulley from spinning
Old Apr 16, 2004 | 05:00 PM
SplitFire's Avatar
I'm trying to get the crank pulley off, but whenever I try turning the bolts, it just spins. I'm using a breaker bar but still no luck. Do you think I'll have to have someone with an air ratchet loosen them up, or is there a way I can keep it from spinning. Thanks.
Old Apr 16, 2004 | 05:59 PM
GreenDemon's Avatar
Get a couple long screws and thread them through the holes on the outside of the pulley, use a wrench to hold the screws and have a buddy try to loosen the screws. It's a pita but it seems to work.
Old Apr 16, 2004 | 08:58 PM
94Z28WP's Avatar
I stuck a skinny prybar through one of the balancer openings and rested it against the block securely and broke the bolts loose.
Old Apr 16, 2004 | 11:36 PM
bad95z28's Avatar
what he said
Old Apr 17, 2004 | 09:00 PM
SplitFire's Avatar
Smile
Thanks, that did it
Boss002
Jul 9, 2015 03:33 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
Rde Bandit
Mar 21, 2015 10:17 PM
