How do I install Tranny Temp Gauge?
Old Mar 19, 2004 | 06:46 PM
OnefstCamaroZ28's Avatar
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
I got an Auto Meter Dual Guage Pod, and a Cobalt Tranny Temp gauge. How do I install it, what do I wire it to? Any help will help me out a lot
Thanks!!!
Old Mar 19, 2004 | 07:03 PM
1msfyter's Avatar
For the transmission, put car up on ramps. On the driver side is a
access plug. Remove it and replace with the sender that comes with the gauge. Run a wire from it to the gauge(go thru firewall hole under PCM)I also put the wire in wireloom to protect it.
I wired mine into the radio wire(hot) It stays on for 10min or until door is open. For the light pull the light switch out and tap into the small brown wire nearest the foglight switch. Test to see if the light comes on when the lights go on.
Hope this helps
Old Mar 19, 2004 | 08:23 PM
Hey man thanks alot, i appreciate the help
99TransAmWS6
Feb 12, 2015 07:23 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
Snoman73
Nov 17, 2014 07:22 PM
