how do i get my E break to re-latch?
Old Aug 22, 2004 | 06:15 PM
glennxx1's Avatar
un screwed the one screw on it, soi could get my console out easier (not tear uop the little plastic boot around e handle , and the metal rod/button/hook came out and now i cant re attach it..whats it latch too? and how do i relatch it?
Old Aug 22, 2004 | 07:49 PM
glennxx1's Avatar
Re: how do i get my E break to re-latch?
no one know?
Old Aug 22, 2004 | 08:11 PM
Black94mula's Avatar
Yea, just gotta kinda fiddle with it. Put the button/rod in and take a skinny screwdriver or whatever will fit inbetween the arm and push the rod near the hooked end upwards. Kinda hard to explain but, while your doing this, be pushing the button like you were trying to release the brakes. It'll finally snap back in place. Key is, you gotta have something to push that rod upwards to get behind that release tab. Real technical eh?
Old Aug 22, 2004 | 08:58 PM
glennxx1's Avatar
gotcha preciate it
Old Aug 22, 2004 | 09:45 PM
glennxx1's Avatar
man what am i trying to re latch it too? i can barely see in the groove, and i cant see anything i should be trying to connect it to, and man is it frustrating
Old Aug 22, 2004 | 10:57 PM
camarokid24's Avatar
Man I had the same problem a while ago. I messed with mine for like an hour, freaking out thinking I'll never get it back on There is this peice that pivots down in the bottom that the metal hook thingy attaches to. For me my problem was that is was fliped up in the wrong position so it wouldnt grab. You need to stick you finger in there and flip it the other way while you try to reattach the hook thingy (not the technical name ) I hope this helps you sorry if I am beening too vauge , Good luck
Old Aug 23, 2004 | 08:26 AM
glennxx1's Avatar
gonna try to flip it like u said, is it located in teh actualy thin metal handle or down in there? (i dont think my finger will go in the handle)
Old Aug 23, 2004 | 09:51 AM
atljar's Avatar
Un bolt the two bolts holding the entire handle down. Attach the cable to the handle "cam lobe". Pull really hard on the cable, and clamp it off with vice grips. That should give you the slack to put the bolts back in.
Old Aug 23, 2004 | 12:52 PM
glennxx1's Avatar
i finaly got it, found that thing that was fliped upside down, snaped right in
Old Aug 23, 2004 | 01:03 PM
great! sometimes you get lucky and its something so simple.
Old Aug 24, 2004 | 02:53 PM
Yea it only takes like 1 minute to do it. Helps to take a flashlight the first time and see what your hooking it to.
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Aug 17, 2015 09:50 AM
Cam's maro
Aug 11, 2015 07:45 AM
