how difficult is installing new roller rockers>
Re: how difficult is installing new roller rockers>
yeah, i have that site saved in my favorites, but it looks like the bolts aren't that deep wher you will need a deep socket? don't want buy a set if i can do them with a regular sockets.
Originally Posted by foxbat
if i were to get the LT4 stuff, what would i need? is there a kit that has everything?
40-10758-16 Crane Gold Self-Aligning, Narrow Body Rocker Arm for Center Bolt Valve Cover, 3/8" stud, 1.6 Ratio
Is this the part number for the Crane Rockers...from thunder racings site?
If you go w/ LT4 spring you should /need to get the LT4 retainers/locks. The stock LT1 retainers/locks are not used to the added spring of the Lt4 sprigns as they are stiffer. Especially if your motor has more then 70K on it. You dont want to drop a valve and blow your motor. Get the right hardware.
If you don't have a deep socket set, buy one now as you will need it sometime. As for a kit you might just want to buy the hotcam kit. Its about $550 last i heard and comes with rockers, springs, retainers, i believe locks and even a cam if you decide to add that later.
Dec 4, 2014 11:56 AM
