How could I tell if I have a blown head gasket?
Old Jun 19, 2004 | 07:35 PM
warwickbass's Avatar
Yeah.
Old Jun 19, 2004 | 07:58 PM
IllusionalTA's Avatar
Well the most common and easiest tell tale is a enormous amount of white smoke out the tail pipe's.. Water in your oil is another common symptom.. I'm sure there are others..
Old Jun 19, 2004 | 08:33 PM
Alex94TAGT's Avatar
Compression and/or Leak-down test would probably be the most useful, but coolant entering the combustion chamber will cause white smoke as IllusionalTA stated above (-should be fairly obvious if you're burning coolant)...
Old Jun 19, 2004 | 09:59 PM
ibanez6rg's Avatar
Check for coolant in your oil and vice versa.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
