How to confirm Opti is gone?
Old Mar 20, 2004 | 09:32 PM
SilverFormula's Avatar
Well my car started hesitating on the way home and when i finally got to the drive way, it died on me. Now it wont start. Is there anyway to be sure its the opti spark?
thanks
Old Mar 20, 2004 | 09:49 PM
OK UPDATE......... I let the car sit for 20 mins and now it will START, but when i give it gas, it bogs......
What could that be?
If any of yall are really good with lt1s and live in the DFW area, i might be needing your help soon.'
Also, anyone with info can IM me on aol/aim at Speed3000gt
im stuck at home and online for awhile( its 9:50pm sat night right now)
thanks
Old Mar 20, 2004 | 10:33 PM
white97z/28's Avatar
Hate to say this but sounds like you might be out of gas, check it. If not could be your fuel pump. Also, check plug wires and see if it is throwing a code.
Will one of those code checkers at autozone tell me what the exact problem is?
do they have codes for the opti going out?
Old Mar 20, 2004 | 10:37 PM
yeah, autozone will scan it for you, but probably wont be able to tell you what it is, the good thing about it is that you can get the code from them and look it up on shoebox's tech page at http://shbox.com/1/4th_gen_tech1.html. there is a list of codes there that will tell you like the opti and stuff. It seems like the opti is 15... or 16.... somthing, cant remember.
Old Mar 20, 2004 | 11:16 PM
Theres about 1/4 tank of gas left. but how do i check out the fuel pump?
Thanks for your help!
Old Mar 20, 2004 | 11:34 PM
Seal's Avatar
sounds like the opti to me
Old Mar 21, 2004 | 12:07 AM
Revis_Racing's Avatar
turn the key to the on position with radio/ac off. listen for the fuel pump to prime the lines. or use a fp gauge.
I'll bet its the opti though.
did the car have a slight skip or miss to it before it died?
Old Mar 21, 2004 | 01:25 AM
flowfx's Avatar
Ive had this problem a few times since I've owned the car (2 years)
Usually it'd be after sitting for a day or two (weekend) and then waking up on monday to goto work.
I found out if I rev it while its cranking over, and hold the rpm around 2k for about 30-1minute, itll blow out a bit of black smoke and the car when then run fine, or idle at 500rpm.
My car also idles at 500 pretty often now, its gotten worse over the past year. Most people point it towards my opti, or my ignition system in general.
Usually it runs fine at 500 althrough the oil pressure that low really worries me. Sometimes it wants to go below 500 and it begins to feel like its gonna choke and die.. Usually at lights Ill pull the ebrake up and rev (m6) to 1k.
Old Mar 21, 2004 | 01:19 PM
HBHRacing's Avatar
you can use this link to test the ign and fuel systems to figure out whats going on. but of you say when it starts and you hit the gas it just bogs I am going to guess fuel problems.
Check it out http://mainstreamtopics.com/forum/in...p?showtopic=78
Old Mar 21, 2004 | 01:25 PM
flowfx's Avatar
I was wondering what's the easiest way to tell if your optispark is vented?
I have a MY95 formula, but according to carfax it was BUILT in Canada, I'm pretty sure something I read said '94
Are ALL MY95 cars vented? Doesnt matter when it was built, long as it's 95?
Old Mar 21, 2004 | 02:11 PM
mkent's Avatar
i want to say it's the fuel pump. my 94Z did the same thing a couple years ago. i could drive for a while and it would just die and wouldnt' start. after i let it set for a while it would start right up! same thing happened with the old Buick Regal
Old Mar 21, 2004 | 02:28 PM
moparman's Avatar
Autozone can not pull codes from OBDI cars. And the '95 is even worse. It has OBDI diagnostics with an OBDII connector. '95 owners will have to find someone with the proper equipment to pull codes or scan the engine.
Old Mar 21, 2004 | 02:48 PM
Well i think it was the gas because i put in some B12 chemical tool and let it run for a couple of mins, then drove it to the gas station and put some high grade gas, and it runs fine now...... also, the "silencer" was missing from my intake system....
i clogged it with a cap but whats a good fitting object that will be a perfect fit besides what they sell for 35$
Old Mar 21, 2004 | 03:58 PM
HBHRacing's Avatar
remember.. when our cars are close to the 1/4 on the gauge we are damn near out of fuel...
might be a good time to change your fuel filter
