How compatible is the LT1 to a SBC?
Old Jul 20, 2010 | 08:45 PM
razor02097's Avatar
How compatible is the LT1 to the Gen 1 SBC?
I know the cam, block, heads, and opti are unique to the LT1 but what about intakes, headers, and other bolt on components? (talking about what fits the block not what fits the F body)
How about the rotating assembly, valves, push rods, lifters and valve springs?
I tried a search but got too much non relevant threads, pages and spam to put together a conclusion.
Old Jul 20, 2010 | 08:51 PM
RamAir95TA's Avatar
Any rotating assembly designed for a 1-piece rear main seal will work with the LT1.
Any SBC intake manifold can be made to work with the LT1, but they must be converted (a bit pricey but becoming more and more common). No SBC will bolt right on without modification.
Any SBC headers will also work, but be aware that the LT1 used D-shape exhaust ports. As long as the header isn't blocking any parts of the exhaust port they will work (and bolt up) just fine.
These are just a few things off the top of my head. Others will chime in I'm sure.
Old Jul 21, 2010 | 12:32 AM
pgerst's Avatar
The only thing I know of that is a direct bolt in from SBC to LT1 is the oil pump.
Old Jul 21, 2010 | 10:22 AM
brucer's Avatar
i thought the cam from an lt1 would work in an sbc, but the sbc cams wont work in the lt1..
cyteone
Feb 7, 2015 06:04 PM
rwferguson43026
Feb 6, 2015 10:06 AM
Jan 23, 2015 01:13 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
squinn
Aug 4, 2002 01:06 PM
