How close is too close for exhaust to fuel lines?
Old Nov 1, 2004 | 10:49 PM
Formula03's Avatar
I am getting ready to fab up a dual kit and I noticed that where I want to run the pipe it would be really close if not touching the fuel lines. So how close can they be? Is there anything that I could insulate the lines with so it wouldnt matter how close they came to each other.
Old Nov 2, 2004 | 12:24 AM
captain_foustas's Avatar
Re: How close is too close for exhaust to fuel lines?
if they are even REMOTLY close they will burn. trust me..i know
oh yea, i suggest you use zip ties
Old Nov 2, 2004 | 01:17 AM
atljar's Avatar
Some sort of heat shielding. I used a thin sheet of metal when i had a cats on my longtubes to cover the lines there. You could also bend them a little out of the way.
You can see the shield i added here on the left when i had my new Y made after the one with cats.
http://atljar.com/P1010012.JPG
Old Nov 2, 2004 | 11:38 AM
95RagtopTA's Avatar
I used a roll of heat shield tape and some zip ties (the adhesive on the tape didn't last too long). Got the tape from Jegs, its got an aluminum coating over an insulated fiber cloth--works well....
Old Nov 2, 2004 | 11:42 AM
Formula03's Avatar
So, if they are insultated well you can have them touching or close to touching
Old Nov 2, 2004 | 01:44 PM
95RagtopTA's Avatar
In a couple places, I think my Y-pipe is an 1 1/2 from the lines. I was told the tape can actually touch the headers/exhaust without burning.
Old Nov 4, 2004 | 04:47 PM
Formula03's Avatar
Alright that helps a lot. thanks guys
Old Nov 4, 2004 | 05:35 PM
TobyZ28's Avatar
The best scenario is that theyre NOT touching and that the insulation you put on it is not touching either.
Old Nov 4, 2004 | 06:51 PM
OldSchoolSS's Avatar
why not just relocate them to run along the inner rocker panel? Then you don't have to worry about it. Fuel line is really cheap it shouldn't be that hard to do. That's what I was planning on doing when i did my duals this winter.
Old Nov 5, 2004 | 12:01 AM
Formula03's Avatar
That is the best idea I just didnt want to have to mess with moving them but I probably will.
Old Nov 5, 2004 | 08:33 AM
BigEvil's Avatar
Just like altjar said. I welded in a plate to interrupt the heat transfer. Seems to have done just what it was supposed to.
Killer94z
Jan 13, 2015 12:06 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
guionM
9
Aug 29, 2002 01:48 PM
