How to clean IAC
Old May 2, 2004 | 12:20 PM
ASIM's Avatar
How to clean IAC
Hey guys:
How do you go about cleaning out the IAC. I cleaned my TB last year and think I got some gunk that ran into the IAC.
Thanks,
Asim
95 Z28 M6, 17 Speedline, Borla, H&R, Polk audio...
Old May 2, 2004 | 12:35 PM
Some spray TB cleaner and a toothbrush and you might want to clean the passages in the TB. Don't push or pull on the pintle or turn the key ON when you have it disconnected.
Old May 3, 2004 | 08:27 AM
ASIM's Avatar
I think that is how I got into the spot of needing to cleaning the IAC. I sprayed TB cleaner in the and scrubbed with a toothbrush. I think some of that carbon got onto the IAC. What is the best way of cleaning it?
Asim
Old May 3, 2004 | 08:50 AM
ASIM's Avatar
Sounds good.
Where is it. And how does it pop out. What does it look like.
Thanking you in advance.
Asim
Old May 3, 2004 | 01:44 PM
ASIM's Avatar
So I just un-screw and pull out. No need to remove the TB?
Asim
Old May 3, 2004 | 01:59 PM
blown383's Avatar
you need to remove the TB inorder to service the IAC.
-B
Old May 3, 2004 | 02:04 PM
TobyZ28's Avatar
There is also a gasket thats between the TB and Intake area, so just be very careful not to break it and you can reuse it, or just get a new one from GM, I'm sure shoebox's page has a P/N for it.
Old May 3, 2004 | 02:14 PM
Tim240z's Avatar
[thread hijack]
Since we're talking about TB gaskets, what's up with teh rubber POS gasket under the top cover of the TB. IT's very obviously not impervious to oils as it swells up and is then pretty much unuseable. Can the cover just be sealed up with a thin bead of silicone around the perimeter sealing area?
[/thread hijack]
Tim
Jeff1904
Jun 5, 2016 05:00 PM
marlar98
Sep 19, 2015 07:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
tdigger9899
Sep 7, 2015 10:56 AM
