How to check TEMP gaudge?
Old Oct 5, 2004 | 06:58 PM
budvol's Avatar
Got my oil leak fixed.
Mow my TEMP gaudge is not going past the 1st mark or so. even when i let it sit and idle till the first fan kicks on.
Its getting power cause u can see it move up till that 1st mark from a cold start.
But no higher
Old Oct 5, 2004 | 08:57 PM
trans9_5am's Avatar
Re: How to check TEMP gaudge?
As soon as you learn how to spell "gauge" correctly, im sure someone on here will be glad to help you
Brandon
Old Oct 5, 2004 | 10:43 PM
Take the wire off the sensor, ground it (with key ON) and see if your gauge fully deflects. If so, you have a bad connection to the sensor or a bad sensor. If not, you have a problem with the circuit or gauge, itself.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
