how to check my cam grind number
Old Mar 2, 2007 | 03:12 PM
69z-28's Avatar
i got a cam used off a member here and was wondering how i would check to make sure it is what i think it is. all i see on the back of the camshaft is "2307 4" and the 4 is kinda isolated by istelf. then in between the distributor gear and the first lobe it has "1578" on it and it has white paint over it. then more towards the front there is red paint right before the first lobe and it says "27" with a circle around it. idk what any of this means but im hoping someone can make shed some light on the issue. it is supposed to be a Comp Cams 503.
Old Mar 2, 2007 | 03:33 PM
1redTA's Avatar
re
go to comp's website and you can look it up there
Old Mar 3, 2007 | 12:27 AM
69z-28's Avatar
it has grind numbers but nothing that compares remotely with what i have on mine. the only thing im thinking is it has 230 in the one main number on the end and 230 is the exhaust duration number. otherwise i have no idea.
Old Mar 3, 2007 | 10:02 AM
Ricardo's Avatar
I have a Comp Cams 503 cam that I never installed in front of me.
It has the following grind numbers in the back:
LT1 3314S/3315S HR112.
These numbers identify the corresponding 224/230 lobes in their cam lobe master catalogue.
RG
Old Mar 3, 2007 | 12:08 PM
Z95m6's Avatar
RG
Yeah my old XE cam had the lobe numbers ground right on it, same as my buddies.
Old Mar 3, 2007 | 06:00 PM
69z-28's Avatar
hmmm, the only thing with those numbers tho is that on summits site and comp cams site, it says the grind number on the 503 is supposed to be this:LT1 XR276HR-12
whats the difference between the number comp and summit have listed and the one you guys say is on the cam?
Old Mar 3, 2007 | 06:21 PM
Z95m6's Avatar
The numbers listed on the back of the cam is usually the Lobe numbers while the number summit has is like the cam ID number or grind number i believe.
Old Mar 3, 2007 | 06:45 PM
69z-28's Avatar
o gotcha. i read now in the comp master lobe guide thing. makes sense, but is the grind number that comp and summit have listed, actually ground into the cam itself or are only the lobe numbers like you guys have listed above?
Old Mar 3, 2007 | 08:48 PM
Ricardo's Avatar
Besides the information I listed before, there is also a serial number written down in the back of the cam. This serial number appears also in the spec card supplied with the cam.
RG
Old Mar 3, 2007 | 10:55 PM
seawolf06's Avatar
Sounds like a custom cam. Get a cam doctor for it and you'll be good to go.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
