How to check a Meizerre electric water pump?
Old Jun 19, 2007 | 04:29 PM
CANTONRACER's Avatar
I turn it on and I hear it running....I took it out and turned it on and it turns clockwise....I have it on a relay and it is getting 12 volts.
The reason I ask is I used to have a electric waterpump on an old Mopar of mine and that pump if I pulled off a radiator hose would shoot water 30 feet out.
I have tried every hose with mine and I get nothing?
So, how can I test it minus taking it off the car and putting it in a waterbucket?
Old Jun 19, 2007 | 08:20 PM
seawolf06's Avatar
Mine pushes water out of my radiator if I run it with the cap off.
Old Jun 19, 2007 | 10:10 PM
Dan Parker '96's Avatar
Have you run the engine with the pump installed? "Squirting" a certain distance sounds Arkansas to me. Do you actually have an overheating problem?
Old Jun 19, 2007 | 11:30 PM
Well, Arkansas or not, how else do I make sure the thing is actually working?
Old Jun 20, 2007 | 11:09 AM
O J's Avatar
O J
When I had one, if I heard it running and my temp stayed low, that was good enough for me.
Old Jun 20, 2007 | 11:50 AM
Shon Herron's Avatar
I would turn the key on and let it run and then take cap off and see if it is pushing water.
Why would you think it is not working if you hear it? is the car overheating? there might be blockage.
how fast was the MOPAR pump running? I dont remember the GPM but to make the comparison you need to know alot more info.
Old Jun 20, 2007 | 04:08 PM
Harvey's Avatar
Thumbs up
Ditto on the taking the radiator cap off method. Thats the only way I know how to tell.
Shon Herron, if I'm not mistaken, I believe the regular Meziere pump puts out something like 30-35 GPM and the heavy duty version is like 55 GPM.
Old Jun 20, 2007 | 04:33 PM
Dave1980's Avatar
Cant you measure the ouput based on a ten second period? Then you should take 35/60 = x/10 x=5.83 gallons for 10 sec. Not sure how the pumps are designed, but this would be how I would do it.
Old Jun 20, 2007 | 04:50 PM
With the cap off...no thermostat...car not running...all I see is a small little stream of water that is coming from the back of the passenger head. That is it....and the car runs a little hot for my comfort.
I would think there would be a flurry of activity in the radiator?
Old Jun 20, 2007 | 05:58 PM
smoknta's Avatar
How hot is a little hot? Just curious.
HectorM52
Jul 30, 2017 11:46 AM
BMX Dad
Jan 23, 2015 07:00 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
