how to change rear spring rubber seats, and what silicone to use?
Old Mar 4, 2005 | 02:46 PM
tanker's Avatar
How to change rear spring rubber seats, and what silicone to use to prevent the spring from moving? My brother’s car developed some clunking in the rear passenger side wheel after fuel pump change; It is not shock or spring, mechanic suggested rear spring rubber seats. I know how to get the shock out, and how remove springs, but I never changed the spring seats yet. Anyone can save me some time . Also where can I get decent priced rubber seats?
Old Mar 4, 2005 | 02:58 PM
OBE1 95Z28's Avatar
Re: how to change rear spring rubber seats, and what silicone to use?
The spring "seats" aren't supposed to be glued in place. The end of the rear spring coil needs to aligned with the seat...if you look at the seat you'll see a "step" where the end of the spring needs to butt against. The seat also has a feature that lines up with a bump on the body.
Old Mar 4, 2005 | 03:03 PM
tanker's Avatar
I read a post that a spring seat must have some silicone on to prevent the spring from turning on it. I had in mind to use the silicone to keep the spring from turning. Any advice on removing the spring seat?
Old Mar 4, 2005 | 03:05 PM
OBE1 95Z28's Avatar
The spring seat should just pull off easily once the spring is remove. Most times mine fall off after the spring is out for 10 minutes or so. I've got 146K miles on my Z28 and never had an issue with the springs/seats rotating.
Old Mar 4, 2005 | 03:09 PM
tanker's Avatar
Me neither, my spring is fine, and it was removed twice. But my brother's z-28 has some clunking. So spring seats don't go bad?
Old Mar 4, 2005 | 04:24 PM
RE AND CHERYL's Avatar
You don't need silicone to keep it from moving, it's got a car sitting on top of it to do that.
Old Mar 4, 2005 | 04:27 PM
Deckstripes's Avatar
No way silicone could hold a spring from moving. They were probalby just trying to hold the isolator on for easy install. You can do the same thing with 2 small wraps of electrical tape. Nobody will ever see it.
FredM
Dec 18, 2014 01:40 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
wytblur
Mar 2, 2003 03:40 PM
