How can you tell if you have good compression on a motor???
Old Jun 6, 2004 | 03:14 PM
TexasTechTA's Avatar
besides doing a test...
just wonderng because I am a perfectionist, the car starts very strong and fast, does not use any coolent, does not use any oil. And also the dyno numbers are below and the curves looked very smooth. would you think that compression is pretty balanced? also there is 102k on the motor
Old Jun 6, 2004 | 04:42 PM
A test is the only way I know of.
Old Jun 6, 2004 | 05:20 PM
I know but a healthy motor with good comp starts up quick and does all the other above things right?
you can tell usually by looking at that right?
Old Jun 6, 2004 | 07:55 PM
Punkillr's Avatar
do a compression test. i think????!!!! ah jp yea buy a compression checker and pull the plugs out put that bitch in crank it 3 or 4 times and ul get a constant reading. if ur lucky they will all be around 3 percent of each other
Old Jun 6, 2004 | 08:20 PM
I know I cna do a test but thats not what I am asking with what I have said does that describe a healthy compression of motor?
Old Jun 8, 2004 | 05:19 PM
Punkillr's Avatar
it will run smooth no stumbles hesitations. a good compression engine will have alot of power, and check the spark plugs, u can learn alot about ur car from them.
HectorM52
Jul 30, 2017 11:46 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
