how to bleed front brakes
Old Mar 12, 2004 | 12:38 PM
z28marine's Avatar
To switch over to the LS1 brakes you need to bleed the brakes...how do you do this? Can you just do the font ones, or do you have to do all 4 brakes?
Old Mar 12, 2004 | 02:53 PM
z28marine's Avatar
TTT...
Old Mar 12, 2004 | 02:58 PM
Zack's Avatar
to bleed brakes, start from the one farthest from the master cylinder. have somone pump on the brake pedal 3 times or so, on the last pump, hold the brake pedal down, open bleeder valve on caliper till fluid/air is out. close screw, release pedal
Rod Bender
Nov 7, 2023 02:30 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Alien
Jun 27, 2015 01:13 PM
Brake_L8
Jan 20, 2015 09:44 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
