how big is too big?
Old Dec 15, 2003 | 09:41 PM
whitedakota's Avatar
Question how big is too big?
im in need of a new fuel pump (i think) anyways after the car sits for a few hours you have to cycle the key for it to start...and the fuel pump runs o.k i guess, but it will just crank and crank then finally start.
is the 255 to much for the mods i have...i plan on going with the 224/230 in the future and some long tubes to go with it, and some svo 30lbs injector.
thanks for you info.
steve
Old Dec 15, 2003 | 09:42 PM
scoobysnax83's Avatar
Its more than likely your bleed back valve. Unless you're having problems with stutter at high rpms. You may be able to save yourself a lot of time and headaches, as well as money...
Old Dec 15, 2003 | 09:45 PM
bleed back valve???
is that the same as the fuel pressure regulator?
steve.
Old Dec 15, 2003 | 09:49 PM
Originally posted by whitedakota
bleed back valve???
steve.
No... A FPR (Fuel Pressure Regulator) Regulates the fuel pressure throughout the RPM band. A Bleed Back Valve prevents gas from "bleeding" back into the gas tank. Therefore preventing the need for priming. Thats all the info I have on the subject.....
Old Dec 15, 2003 | 09:53 PM
Arrow does anybody know anthing about a bleed back valve?
whats and where is the bleed back valve?
steve...
anyone
Old Dec 15, 2003 | 10:37 PM
simple's Avatar
http://web.camaross.com/forums/showt...hreadid=169541
read that, in that thread there is a link from "Shoebox" that will help ya trouble shoot if not fix it
bunker
Jan 30, 2016 08:09 PM
Sep 18, 2015 03:46 PM
NewsBot
Aug 3, 2015 02:40 PM
Louey
Pacific
Jul 27, 2015 09:58 PM
Boss002
Jul 9, 2015 03:33 PM
