How bad are slp shorties?
Old Mar 14, 2005 | 04:13 PM
kc9328's Avatar
I have a cc306 cam and stock lt4 heads with slp shorties. How bad are these for this setup. Would I see a big improvement with long tubes?
Old Mar 14, 2005 | 04:26 PM
trans9_5am's Avatar
Re: How bad are slp shorties?
Doubt you would see much gain at all with long tubes over the SLP shorties.
Brandon
Old Mar 14, 2005 | 05:42 PM
Antz97ZNJ's Avatar
any headers on an LT1 is a big improvment...if you have to go shorties slp 1 3/4's are the way to go
Old Mar 14, 2005 | 05:52 PM
92rslt1's Avatar
those are good headers they flow very comparable to long tubes the switch isnt worth the gain IMO.
Old Mar 14, 2005 | 06:57 PM
turbo_Z's Avatar
Supposidly the power will be about the same but the LTs produce more low end torque.
Old Mar 14, 2005 | 08:54 PM
Antz97ZNJ's Avatar
Originally Posted by 92rslt1
those are good headers they flow very comparable to long tubes.
I wouldnt go that far...definately the best flowing shorties though, many have made they switch from slp to Lts and noticed a big differance.
Old Mar 14, 2005 | 10:47 PM
SS MPSTR's Avatar
As with anything, your results may vary.
Old Mar 15, 2005 | 12:29 AM
SStrokerAce's Avatar
The new Pop Hot Rodding on the stands has a good exhaust article by David Vizard. That guy has tested more exhausts than anyone i've ever seen.
Hell i've seen a larger diameter header with the same runner lengths and a cam to match make MORE TQ down low and up high, esentially flatten out the TQ curve (like a supposed wider LSA will do) than a smaller diameter header and a bigger cam. Hmmm more HP after peak and more TQ before peak, sounds like more average power and a quicker car to me.
Bret
Old Mar 15, 2005 | 12:48 AM
Loony's Avatar
Bret
Which issue is it? I'd like to pick that up. TIA
Old Mar 15, 2005 | 01:14 AM
It's got a big Aluminum Hemi on the cover with a King Demon carb on top. May 2005
F'n1996Z28SS
Aug 23, 2023 11:19 PM
MDZ28
Exhaust System
Apr 29, 2015 07:44 PM
slocody
Feb 10, 2003 01:04 PM
turbo_Z
Aug 19, 2002 10:50 PM
