How to attach heater hose?
Old Oct 22, 2007 | 07:13 PM
p mulhall's Avatar
Hi,
My heated hose ruptured a pinhole leak today. It attaches to the water pump and then connects to an aluminum flange on the other end. The GM part number is 10188037 for the hose. It is easy to attach the new hose to the water pump but I need to know how to attach it to the other end with the aluminum flange.
Please help as it is not drivable right now and it is my only car...
Thank you.
Old Oct 22, 2007 | 07:45 PM
sandman2100's Avatar
Gm told me to cut the outside of the crimp (swaged) end off leaving a lip. The hose is just pressed onto a barb, the swaged. Just cut around and through the aluminum, then slit that down the middle and bend it off. The hose pulls right off after that.
After you cut it, use the lip that you left as a stop when you put the new hose on, then use a regular worm gear clamp to clamp it down.
Old Oct 22, 2007 | 10:28 PM
p mulhall's Avatar
Thank you for the quick response...I just got in from working on it...did exactly what you said...cutting the swaged end off...just need to buy the hose clamps...THANKS!
Old Oct 23, 2007 | 08:36 AM
Not a problem, just glad I could help out
magman
Apr 15, 2016 03:08 AM
KYWes
Sep 26, 2015 08:49 AM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
