how to adjust timming on lt1?
Re: how to adjust timming on lt1?
It depends what you are tring to do? it will probably advance the timing a bit but the stock timing is pretty aggressive. I would actually stay away from the "chips" have pcm for less or ion on the bored here burn you one.
jb4xx
Feb 2, 2015 10:00 PM
get out your lap top, cable and either tuner cat or lt1 edit. Do a search on either and you will find a ton of stuff.
