How to adjust 1.6 Comp Cam Magnum Tip Roller Rockers w/ Lock Nuts
How to adjust 1.6 Comp Cam Magnum Tip Roller Rockers w/ Lock Nuts. I need to know the correct way of doing this and if there is a way without running the engine and doing it at that time. Can't I just put them on, tighten them a certain way then do like a 1/4 turn. Or do I have to rotate the crank until the it's on compression or exhaust strokes?
Re: How to adjust 1.6 Comp Cam Magnum Tip Roller Rockers w/ Lock Nuts
Remember EOIC. Exhaust Opening, Intake Closing. Turn the motor over until the exhaust valve on Cyl #1 is opening. As it's on it's way down, adjust the INTAKE valve. Now turn it over until the #1 Intake valve is closing. Now adjust the EXHAUST valve. Stock lifters will like 0 lash plus 1/4 turn. Comp R lifters like 1/8 of a turn. HTH.
Originally Posted by 96camaroz28lt4
What about LT4 lifters. I have chromemoly pushrods, cc306 and cc1.6 rockers.
What numbers do you think I'm making?
(New Engine w/ 10,000 Mi.)
-Comp Cams 306 Hydraulic Roller Cam
-1.6 Ratio Magnum Tip Roller Rockers
-Comp Cam Chromemoly Push Rods
-LT4 Hydraulic Roller Lifters
-LT4 Knock Module
-Magnecor 8.5mm Competition Wires
-Edelbrock Midlength Headers
-G2 Cold Air Intake
-K&N Air Filter
-Ported MAF Sensor
-GM Performance Timing Chain
-180 Thermostat
-Air Foil
-Crane Cams 10308-1 Valve Springs
-No AIR
-No EGR
-Royal Purple Fluids
-Stage 2 Clutch
-Free Mods
-Hypereutectic Pistons
-Bored .060
-Computer dyno tuning By Speedworks
-LT4 Knock Module
-G2 Cold Air Intake
-K&N Air Filter
-Ported MAF Sensor
-180 Thermostat
-Air Foil
-No AIR
-No EGR
-Stage 2 Clutch
-Free Mods
-Bored .060
Originally Posted by NastyTA
Tighten it until you can't spin the pushrod with your fingers, then 1/4 or 1/8 turn.
96camaroz28lt4: my guide tells how to find zero lash and add preload. Apparently you are resisting reading or ignoring info links that have been given.
Originally Posted by shoebox
If you can't spin the pushrod, you are past zero lash.
LOL....
I simply told how I adjust the valves on a small block. Never had a problem of being too loose or hanging them open. There are tons of different ways to do it, this is what I find to be the easiest, especially on an LT which is a PITA anyway.
oldschool
Feb 9, 2016 09:21 PM
