Hotcam/Shifting
Old Apr 24, 2005 | 07:43 PM
Red on Red WS6's Avatar
Hotcam/Shifting
I am getting ready to send my computer in and have some adjustments made. I am wondering what the guy's with hotcam's are shifting at? I beleive mine is set at 5700. Looking at my dyno graph I think I should have it shift at 6000.
Also what is your A/F ratio at I think mine is a little bit lean ranges about 13.8 to 13.4
http://members.***.net/jtb4299/img005.jpg
Old Apr 24, 2005 | 10:54 PM
Re: Hotcam/Shifting
Also at what RPM does your HP start to drop?
Old Apr 25, 2005 | 06:53 AM
RE AND CHERYL's Avatar
Re: Hotcam/Shifting
Hot cam with good heads should shift around 6200 RPM.
AF ratio should be close to 13:1. I would rather be close on the ritcher side than the leaner side.
Old Apr 25, 2005 | 12:23 PM
Re: Hotcam/Shifting
I am still using stock heads and LT4 springs.
Old Apr 25, 2005 | 10:13 PM
calfirebird's Avatar
Re: Hotcam/Shifting
Well by looking at your graph you dont start to drop even when you quit. I say go for around 6200 your still makeing good power at that point. Your abouve 300 from almost 6000 up.
