Hotcam kit into 12s?
Old Oct 14, 2006 | 11:15 PM
ajlew9428's Avatar
I have decided to go a different route with my car. Does this setup look like 12s?
Lt4 hotcam 218/228 525/525 w/1.6
crane gold 1.6 rockers, Lt4 valve springs
52mm ported TB w/ Air foil
373 rear end
Lt4 knock module
pacesetter Lts w/ ORY
magnaflow catback
eiback sportline spring kit
billstein shocks
Bmr LCAs
panhard bar
lt4 Knock module
subframe connectors
strut tower brace
1le intake elbow
Kn CAI
pcmforless mail order tune
Also, if I got the 275 size z06 rims, would it effect speedo?
Old Oct 14, 2006 | 11:33 PM
lt11997's Avatar
Re: Hotcam kit into 12s?
Right now I'm hitting 12.9 and that is without my 3.73 gears and suspension mods. I figure mid 12's are possible next year when I have my 3.73's installed and some suspension work done (1.8 60 fts. with just Et Streets).
The Eibach sportline kit will more than likely kill your 60 ft.
Old Oct 15, 2006 | 12:10 AM
ajlew9428's Avatar
What would you recommend for springs that has a good balance of street and track performance(road coarse, and 1/4 mile)?
Old Oct 15, 2006 | 12:27 AM
Lt1dtpower's Avatar
Hotchkis springs have a nice balance. I cut 1.57 60' with these springs. They drop the car 1"
Joe
Old Oct 15, 2006 | 10:13 AM
LT1BRN's Avatar
you should see mid 12's with some suspension, i got a 13.1@106 last weekend, with the worst conditions you can think about, my suspension was sat up completely wrong, full tank of fuel, 2.73's and launching at idle.
60' was 1.8x.
Edit**
forgot to say that I was runing on the stock tune, stock shift points and really bad fuel. :s)
Old Oct 15, 2006 | 02:00 PM
Red on Red WS6's Avatar
I would say low 12's easy. I am running a 12.5 at 107 on the hotcam and similar mods. except I still have stock 3:23 gears.
Old Oct 15, 2006 | 04:03 PM
526 SS 96's Avatar
I got 12.9 @110 with a hot cam kit and long tube headders and pcm4less tune.
Old Oct 15, 2006 | 08:36 PM
ajlew9428's Avatar
Does anyone know where the cheapest place to get the Lt4 kit is? ( I saw a post from 2002, and the kit was in the mid $300s. What a great example of how our economy is rapidly going to sh*t)
Old Oct 15, 2006 | 11:01 PM
lt11997's Avatar
I paid $600 for mine through Summit and that is with all the gaskets needed, oil & filter, coolant.
Old Oct 15, 2006 | 11:32 PM
ajlew9428's Avatar
how long did it take to install?
Old Oct 16, 2006 | 11:52 AM
lt11997's Avatar
About ten hours from start to finish.
Old Oct 16, 2006 | 12:11 PM
ajlew9428's Avatar
thanks for all the help everyone
Old Oct 16, 2006 | 12:52 PM
OffspringZ28's Avatar
http://www.youtube.com/watch?v=2HSya19P5hc
hot cam + bolt ons + stock rear
Old Oct 16, 2006 | 01:37 PM
Sweetred95ta's Avatar
I had no suspension work and had bigger valves and a gasket match done to the heads. Car went:
12.85 @ 108 w/ 1.99 60 ft. n/a
12.28 @ 110 w/ 1.76 60 ft. n/a with a PI stall
11.33 @ 118 w/ 1.53 60 ft. and NX 100 shot
Old Oct 16, 2006 | 04:16 PM
ajlew9428's Avatar
I read another thread that said hotchkis didnt do a good job on the rear springs for the camaro
lt1xondeck
Mar 18, 2016 07:22 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
Jlo
Jul 22, 2015 05:00 PM
