Hotcam Dyho Numbers (Mustang Dyno)
Pretty good numbers. Mine put down 334 rwhp & 325 rwtq through the cat & full exhaust with the mods below except for the dyno was done on the stock converter. I cant wait to get it back to the dyno after I put the M6 in it and get a few pulls with the offroad pipe on.
-Tony
Edit: Forgot to mention that was on a DynoJet.
-Tony
I plan on the following:
P&P Heads (Stock Valves, Maybe 2.0/1.56)
Intake to match
CC 987 Springs
Hardened Push Rods
CC Lifters
Maybe Custom Camshaft....$$$.
Intake to match
CC 987 Springs
Hardened Push Rods
CC Lifters
Thanks.
Yes I noticed that. I told the guy to run to 6000, but I forgot to mention my tach was off a little.
I also logged Knock on both runs which gave me retard of 5 degrees
. My WOT Timing is set to 42 degrees and dropped to 37 when knock was detected.
I'm confident I could made a sure 10 more rwHP if I fix this knock and run it a little higher.
BTW, I have a 93 so an LT4 KM isn't needed, maybe I'll drop timing a few degrees...
Originally posted by RealQuick
Looks like you gave up an extra 5-10-rwhp by shutting down early. Looks like the curve was still moving up.
. My WOT Timing is set to 42 degrees and dropped to 37 when knock was detected.I'm confident I could made a sure 10 more rwHP if I fix this knock and run it a little higher.
Originally posted by ZPaul2Fresh8
Don't know, didn't have the wideband hooked up.
Don't have a bung for it. Maybe next time.
I hear 12.1 ~ 13.1:1 is best for N/A... any thoughts?
The guy I talked to at the Shop said it's best to have it as close as possible to the engine.
Maybe if I get my H-Pipe exhaust setup, I will put one in the middle.
They wanted only $15 to use the clip on Wideband... should've paid for it.
Doesnt matter as long as you dont have cats on.
an lt4 km isnt needed on a 93?
Thanks.
Thanks.
For getting your heads p&p and a custom cam talk to nighttrain66. Cool guy and will help you with your setup. At the moment he's working my heads over and I went with the LE3 package which cam is matched to the flow of my cylinder heads. A member of the board made 409rwhp with this package on the stock bottom end.
