Hotcam Dyho Numbers (Mustang Dyno)
Old Mar 27, 2004 | 04:16 PM
ZPaul2Fresh8's Avatar
Hotcam Dyno Numbers (Mustang Dyno)
LT1/A4: 320 rwHP / 331 rwTQ
Mods:
Hotcam Kit, Longtubes, Lid & Borla
Dyno Run Graph
Old Mar 27, 2004 | 05:21 PM
stereomandan's Avatar
Sweet numbers with the A4 and Hotcam.
How do you like the driveability and sound? Is the engine itself much noisier with the hood popped?
Congrats!
Dan
Old Mar 27, 2004 | 05:33 PM
Thanks.
Driveability is not changed much, sounds nice too. As far as noise under the hood, not bad as long as your rockers are adjusted properly.
Old Mar 27, 2004 | 05:41 PM
jkipp84's Avatar
Great numbers!
Old Mar 27, 2004 | 05:49 PM
Thanks, I took a pic of the graph and posted it above.
Old Mar 27, 2004 | 06:48 PM
simple's Avatar
stock tune or? those seem about right i think
i would also think the Hotcam would make peak power a lil bit higher then that too, or am i mistaken?
Old Mar 27, 2004 | 06:58 PM
got_hp?'s Avatar
those are really good numbers on a mustang dyno........they usually are lower than a dynojet
Old Mar 27, 2004 | 07:11 PM
PCM4Less Tune, with a little changes done by myself.
I had 290rwHP before the Longtubes on a Dynojet. Looks like I picked up a cool 30rwHP & rwTQ! On a Mustang Dyno too
Next, LE Heads and bigger cam
Old Mar 27, 2004 | 07:14 PM
mineralwater's Avatar
A4 or M6?
edit: oops, saw that you have an A4. Nice!
I've seen upwards of 335-ish rwhp on an M6, but that was on a dynojet..
nice numbers though The hotcam is definitely a good balance between streetability and power. When I had my car running, it was like having all the fun, low end kick and torque of the LT1 with the topend pull of an LS1. Definitely not a bad mod for $450.
Also, I'm not too sure about LE heads, a couple people I know have seen LE heads flow only slightly better than stock.
Want some good heads? PM "Skaradom" and ask about his heads. A local buddy here (Dr. Mudge) made 411rwhp on a medium-ish cam and phil's heads - stock bottom end, no problems. And that was on a mustang dyno.
Old Mar 27, 2004 | 07:55 PM
FastZinTennessee's Avatar
Re: Hotcam Dyho Numbers (Mustang Dyno)
Nice numbers!
Originally posted by ZPaul2Fresh8
Mods:
Lid?
Old Mar 28, 2004 | 11:36 AM
PICTURE ON THE DYNO
Lid? Yeah MTI Lid. I have an LS1 Front end conversion and SS Hood. So I retro fitted the airbox in conjunction.
PIC OF FRONT END
PIC UNDER HOOD
Old Mar 28, 2004 | 01:28 PM
Interesting!
Old Mar 28, 2004 | 04:00 PM
Oh yeah, I don't have the LT4 heavy duty timing set, so I only took it up to 5700. Maybe I could've made more?
Another guy that went with us made an shattering 519rwHP with his lighty modified 03 Cobra! That thing sounds like a jet when it flies by
Old Mar 28, 2004 | 04:55 PM
No member named Skaradom. Maybe you mispelled it? I tried looking but couldn't find anything similar.
Old Mar 28, 2004 | 06:11 PM
ibanez6rg's Avatar
Na, he changed his boardname to Ai (Advanced Induction) BTW, why the fake SS?
*You probably won't really make any good power above 5700, I'd keep it.
