hotcam
Old Feb 9, 2004 | 10:52 PM
SLeeper94Z's Avatar
hotcam
I just bought a hotcam , just the cam
itself can i jus buy the lt4 valve springs
and use my stock retainers etc?
Old Feb 9, 2004 | 11:33 PM
1loudz's Avatar
well, more often than not the springs will come with new reatainers, but if not, it would be ok to use the stockers, they both will fit up.
Old Feb 9, 2004 | 11:37 PM
TMorgan800's Avatar
You might have to get new lifters. I dont know. They needed to put new ones in on mine. Just a sugestion.
--Troy
Old Feb 9, 2004 | 11:40 PM
T/A#4's Avatar
Don't even think of using the stock springs with the Hot Cam & roller rockers. You will get spring bind = broken springs & destroy the engine. Hold off till you can do it "right". The Hot Cam springs & retainers are cheap !
Old Feb 10, 2004 | 12:05 AM
SLeeper94Z's Avatar
valve springs
yea im going to get the lt4 valve springs
do they come with the retainers ? how much are retainers?
Old Feb 10, 2004 | 10:30 AM
SLeeper94Z's Avatar
ttt
Old Feb 10, 2004 | 02:32 PM
1loudz's Avatar
yes, they come with retainers
Old Feb 11, 2004 | 04:57 PM
y5e06's Avatar
retainers
LT4 springs run about $30 online. LT4 retainers, keepers, and shims (seats) are extra. You can run your stock ones just fine and save a bit of cash. Also, don't forget to replace your valve stem seals while you're in there. Those should run about $30 from GM or $20 from anyold parts store.
HarleyZ28
Oct 5, 2015 06:23 AM
MDZ28
11
Sep 24, 2015 09:15 AM
k1996z28
Apr 13, 2015 06:54 PM
WildRidez
Jan 16, 2015 03:10 PM
stngh8r
West South Central
Oct 22, 2002 03:44 PM
