CamaroZ28.Com Message Board
-   -   hot z (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/hot-z-833191/)
gunsavy Sep 30, 2011 01:04 AM
hot z
i have 1995 z28 that has started overheating so far i have had the system flushed changed the t stat and replaced the water pump i tried bleeding the system but after reading many of the threads i moght not have done it right but what im confused about is why when it overheats is the radiator is not hot i have checked the oil and there is no mix so my guess is the heads are ok i would appreciate any help (the temp has gone up but i shut it off before it got to the red). thanks
Seahawksax Sep 30, 2011 01:37 AM
I had the same problem.. i ended up doin a head job anyways.. it was super warpped on the driver side...i had no smoke and no mix when i took them off
1993 supercharged camaro z28
Injuneer Sep 30, 2011 05:03 PM
Re: hot z
Did you buy a thermostat specifically designed for the LT1's reverse flow cooling system?
Did you read Shoebox's guide to cooling system problems?
http://shbox.com/1/4th_gen_tech2.html#cooling
Do the fans come on when the temperature reaches 226*F?
