Hot Cam guys...What stall converter????
Old Aug 11, 2003 | 03:53 PM
S.J.S.'s Avatar
I'm putting a hot cam in my 383 and wanted to know what kinda stall you guys running with the Hot Cam.
thanks.... s.j.s.
Old Aug 11, 2003 | 04:44 PM
Z28SORR's Avatar
This cam doesn't have much of a bad idle. It's been a while but I believe it was only 2200rpm stall. For sure no more than 2400rpm.
Old Aug 11, 2003 | 04:56 PM
S.J.S.'s Avatar
Man is there anyone I can call... So far I've got seperate replies from 2200 stall to 3200 stalls. They say the powerband is 3000 to 6500. Is that true?
Old Aug 11, 2003 | 06:48 PM
Dan Oldham's Avatar
I don't have a 383, but I do have an LT4 HC setup. I've got a 2400 rpm stall, and I'm happy with it. It's not crazy-high over stock, and it's enough to throw the car up to its powerband nicely.
On the same token, I still wanted to keep the car extremely driveable, and was not willing to sacrifice driveability. I PERSONALLY wouldn't go with over around 2600rpm of stall.
Old Aug 11, 2003 | 07:24 PM
Smokn '94 Z's Avatar
Lightbulb
I am running a 3600 vig right now but when I ran 109 - 110 traps I was running a 3200 Vig. I am probably gonna go back to the 3200 now. It really woke up the cam!! Before 3200 I ran a best of 12.90 and a best MPH of 106. With the 3200 I ran a 12.30 with a best of 110.34 mph. I got greedy by going with the 3600 stall in hopes of an 11 second run on stock heads & it is just to in-efficiant in my opinion. Hits a wall up top. 3200 is optimal.
Old Aug 12, 2003 | 11:53 AM
Z28SORR's Avatar
S.J.S.,
You seem supprised by the different responses. Remember there is no right answer, we're all doing this for differnet reasons. Mine was in an 87 Corvette that was my daily driver that I didn't race. So I didn't need the higher stall and didn't want the extra associated heat.
Smokin' obviously drag races a lot, and wants the higher stall.
So now you have to decide. How am I going to drive my car and what kind of street manners do I want it to have?
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
marine1bird
10
Jan 25, 2015 12:02 AM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
