hoses on water pump
Old Jul 18, 2004 | 09:28 PM
jtk's Avatar
jtk
hoses on water pump
I have a 1993 camaro Z28 which was in a front end collisoin, and has been undergoing extensive cosmetic surgery to put it back together. one thing I am not sure of is on the water pump, there is three heater hose like nipples on it two go the the heater core, were dose the third one on the drivers side go??
I was thinking it was just a extra one because this is a aftermarket carquest pump and pluged if. Is that suposed to be connected to somthing? I can not find any pictures on alldata relating to it
Old Jul 18, 2004 | 09:37 PM
Re: hoses on water pump
Heater hose diagram and radiator hose diagrams available on my Tech Page.
Old Jul 18, 2004 | 09:41 PM
n2ceptor's Avatar
If its located on the bottom driver side it should be the connection to a bypass hose to the radiator.. the hose is connect to the bottom section of the radiator below the upper hose.... I have a '93... I'll go look....
Old Jul 18, 2004 | 09:48 PM
n2ceptor's Avatar
It appears the one connection on the driver side goes to the oil cooler line from what I could see.... The to connection one the passenger side are for the heater core...
Old Jul 18, 2004 | 11:27 PM
jtk's Avatar
jtk
Oh, OK thats why I dont know were it gose I eliminated the Oil cooler when I reinstalled the engine... duhh. I'll just fill it with synthetic and not worry about a oil cooler leaking
Old Jul 19, 2004 | 06:00 AM
Mtrhds94Z's Avatar
If no oil cooler then you need the bypass hose:
http://shbox.com/1/93-94_hoses.jpg
#16 in above diagram from shoebox' site..
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
94Z28LS1toLT1
Feb 26, 2015 07:47 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
