Hose from valve cover to throttle body
Old Feb 3, 2009 | 05:22 PM
deerslayinrenek's Avatar
What does this hose do and would it be ok to just put a breather on valve cover and cover the hole to the throttle body. I tried searching this topic and just confused myself................Thanks
Old Feb 3, 2009 | 05:37 PM
PoorMan's Avatar
It's for venting the crank pressure. Yeah, just put a breather on it. Some say you will get unmetered air but doesn't matter imo. Better than the oil blowby you get into your throttlebody and intake.
Old Feb 3, 2009 | 05:41 PM
'94 Bad A Z28's Avatar
You only get unmeetered air if you don't cap off the other end. Unmeetered air can shut off your motor if there is enough unmeetered air going into the motor.
Old Feb 3, 2009 | 07:05 PM
There should have been detailed explanations in your search for "breather". It's been discussed at length many times. It's not confusing when you understand how the PCV system works and why it is there. It's a whole lot better than a breather for keeping harmful gases out of your crankcase.
Sure, you can "just put a breather on it", but it's not better for your engine in the long run.
Old Feb 4, 2009 | 05:17 AM
And, capping "off the other end" of the hose does noit prevent unmetered (MAF) air from entering the engine. The vacuum source to the PCV valve will be pulling unmetered air into the manifold, via the path from the breather to the crankcase to the PCV valve to the intake manifold.
Stock PVC system, with all the parts intact, works fine on my 800HP nitrous motor. Never had a problem with oil in the throttle body.
Old Feb 4, 2009 | 05:20 AM
..DAMN..'s Avatar
These guys know there **** if it's not working find out why mine was supposed to me all new hoses until i looked myself and let me tell you after all these years your pvc system could use the r&r.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
