Horsepower guestamit
Old Mar 1, 2007 | 08:42 PM
ZL1modified's Avatar
i have the mods listed below and i was want ing to know how much power
the comp pro mags 1.6 NSA rr's and trick flow stock length pushrods would add to the mix...(i have them listed. however, they are not installed yet)
while were at it... should i hit 12's
has anyone dynoed the comp pro mag rr's with a stock cam and lifters?
Old Mar 1, 2007 | 11:30 PM
mrmint69's Avatar
High 12's low 13's if everything is in good running condition.
Old Mar 2, 2007 | 02:15 AM
BiGGinZ's Avatar
I think you should be into the 12's on some drag radials. From what I have read the 1.6's add 10-15rwhp. I could be off on those numbers though.
BiGGinZ
Old Mar 2, 2007 | 08:54 AM
mdacton's Avatar
BiGGinZ
I don't think so
Old Mar 2, 2007 | 12:57 PM
2000GTP's Avatar
I can see you running in the lower 13s. More stall and some weight reduction and you should be seeing high 12s.
Old Mar 2, 2007 | 01:11 PM
speed_demon24's Avatar
mid-low 13's.
Old Mar 2, 2007 | 01:12 PM
Brandon94Z28's Avatar
Realistically I see 13.2 - 13.5 @ probably 104-105
Brandon *sslopok*
95 imp SS with goodies
Old Mar 2, 2007 | 01:23 PM
without these mods (listed below)... i ran a 13.4 @ 103 with a 1.9 60' street tires... i also had plug wires 3 & 5 crossed...
UMI G-force brace w/Tq Arm, UMI SFC's, Comp Pro-mags NSA 1.6RR's, A/C Removal, ASP underdrive set...
i really thought i could see 12's... oh well i'll find out in a month or so...
Old Mar 2, 2007 | 06:06 PM
Z95m6's Avatar
I'd say 12's aren't impossible and you might put down 300rwhp.
Old Mar 2, 2007 | 06:33 PM
CALL911's Avatar
High 200's, possibly breech the 300 hp point. Depending on how sticky your tires are, you might see high 12's. I doubt it on street tires, but with some slicks, I would think its possible.
Old Mar 2, 2007 | 06:56 PM
hulettsz28's Avatar
i think high 12's would be really optimistic, but you never know you might tag a 12 second time slip. more realistically, i would be more than satisified with low 13's.
Old Mar 2, 2007 | 06:58 PM
BiGGinZ's Avatar
Hmm for some reason last night I thought I read you had a 4000 stall...it might be hard to do with your mods and the 2000 stall. Now if you had a bigger stall or a cam you should be in the high 12's. MIGHT be able to do it with a great launch on sticky tires.
BiGGinZ
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Aug 24, 2015 06:41 AM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
