Horrible misfire caused by heat?
Old May 24, 2005 | 06:02 PM
urbaNHunter44's Avatar
Okay, I've been trying to track down this misfire forever.
Plugs and wires have been changed btw.
I've narrowed it down to it only happening when the engine bay is absolutely heat soaked. It's doing it HORRIBLY today, and it's 85 degrees outside. The car runs PERFECT at night when it's cooler.
And it doesn't happen if the coolant temp is high by itself, like if it's been idling on a cool day in traffic. The whole bay has to be hot as hell. It's so bad I can barely drive the car today.
Any ideas? I'm not sure where to start looking on this one.
Old May 24, 2005 | 06:20 PM
blitzer454's Avatar
Re: Horrible misfire caused by heat?
Please post the year built and any other mods.
Possibly the ICM is bad as it is heat sensitive.
Old May 24, 2005 | 06:54 PM
1994 Trans Am GT, 25th Anni. A4, 3.23 posi.
Cat back exhaust, straight pipes with bullet muffler
Air foil
LT4KM
Descreened MAF
I've heard about the ICM from someone else, as well as the cooling mod for it, does this help alot of people? I've never heard of this problem with the ICMs until I told this problem to a few people knowledgable in Fbodys. Is this common?
Old May 24, 2005 | 07:40 PM
ReducedFat's Avatar
I had the same problem, it was the icm. Do the icm mod on shoebox and you'll be golden.
Xiantyl
Jul 21, 2015 05:42 AM
Noct
Jul 14, 2015 01:18 AM
whitehooptie
Jul 12, 2015 06:10 PM
Boss002
Jul 9, 2015 03:33 PM
Jmj93z28
Jul 8, 2015 10:01 PM
