Hooking up a Mallory 685 ???
Old Jun 29, 2010 | 09:26 PM
1slo93z's Avatar
I have a 93 z28 with an opti spark and was wondering if there is a diagram for this to one in the kit does not show an opti spark...I want to use it to pull timming out and use it for a n20 set up. The problem Im having is when its on n20 it pulls great till mid 2nd gear then it starts to surge..It may be fuel preasure also but I think its timming cuz the chip in it the timming is advanced.
Old Jun 30, 2010 | 01:13 AM
red94chicken's Avatar
you can use the msd harness for a dual connector coil. do you have a relay wired in or is the solenoid wired straight to the box? if its wired to the box without a relay you could be overloading it making it turn on and off. or if you have a relay it may be taking a poop. or your power source has a bad connection. or a million other things. pill it for a 75 shot and run it without being hooked to the box.. then you will know if its the box or not..
Old Jun 30, 2010 | 07:34 PM
slowride94z's Avatar
https://www.camaroz28.com/forums/sho...d.php?t=513004
Originally Posted by 2000GTP
Wiring the kit is painfully simple. I would strongly suggest buying the MSD harness for 30 bucks and avoid cutting and splicing into the factory harness. You basically are going to hook up a total of 6 wires to get the box to function, one is for power, one is for ground, and the other 4 will be crimped to the MSD harness which will in turn plug into your ignition coil. Here is the correct color coordination for the MSD harness to the Mallory box:
Red to Red
Black to Black
White to Green
Orange to Yellow
Just follow the instructions that come with the box, it isn't too hard to follow. After that, follow the link provided above to get your window switch and timing retard functions hooked up.
Old Jul 1, 2010 | 12:50 AM
1slo93z's Avatar
Cool thanks Im doing a rear end on it now and that box hopfully it will work out.
KYWes
Jun 14, 2022 06:52 AM
n2oblkz
Oct 22, 2015 02:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
canuck94z28
Aug 19, 2015 05:50 PM
