Hooked up Tech 2
Hooked up Tech 2
I just put my heads back on my car and I'm getting a bad stumble. Mostly in the lower rpm range. It never did this before the heads were ported. I hooked up a tech 2 to the car and everthing looks normal to me. There were no misfire codes. What should I be looking for? If there are no misfire codes, does this mean it could be fuel related. Like I said, this was not a problem before I took the heads off and had them ported and put them back on. Any ideas?
Possibly a vacuum leak around the intake: between the manifold and heads or the fuel-injector o-rings.
How much more flow are you getting with the ported heads? A lean condition caused by the increased air flow or bad fuel pump will cause a stumble.
I don't think it's a lean condition. It is kinda running rich. Mabe a leaky injector or something? What kills me is that it was running perfect before the project, so, it's gotta' be somethin' I did. Anyone ?
Does your PCM reprograming include the porting??
It does sound like a vaccum leak. You could also have incomplete combustion, which would look like a lean condition.
Is everything hooked up?? It may be possible you missed a conector, not saying you did, but it can happen.
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
